Hi Ian,
Assuming you have one static IP address, it should be picked up when you connect to the internet using your correct login details. You can check this by clicking on 'broadband link' within your 2700 and checking what the internet address is.
Then all that is left to do is port forward to your server for whatever inbound services you use. Assuming you've had your server connected to the router, it will show up in the local devices list under local network (if you click on advanced settings, you can see a list of names with IP addresses to make it easy to identify your server). Once you know which one is your server, you can click on the firewall icon, then firewall settings and configure whatever services you need to it by following the instructions on-screen.
Hope this helps,
-Marc
Message Edited by marc on 10-30-2007 08:48 PM
