Re: BT Versatility BBM+ and V-IP Featurephones
Fiona
Grand Guru
Hi RichW
This issue arises when the programming from a BT Versatility Broadband Module (BBM) is saved (backed up) and then loaded onto a Broadband Module Plus (BBM+).  This is because the software on a BBM differs from a BBM+ so if you load the saved configuration from a BBM onto a BBM+ you will only see 2 endpoints and there will be no option for ITP extensions or UM services on those 2 endpoints.  There will also be differences in the firewall configuration.
To get the BBM+ back to normal it will need to be reset to default which can be done through the programming interface under advanced configuration.
We have come across this issue before but it is not a reported difficulty and we have had no reports of the programming interface being difficult to work with.
Yes the screen options do vary slightly with some firmware versions but this is true of any such device as each firmware incorporates new features and functionalities so there are slight changes to the programming interface to implement these.
I hope this helps.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
0 REPLIES 0
