Hi,
I have shelves this probelm for the past few months and carried on using the BT router. Now i wan't to start adding VoIP lines to the Versatility system so i have no choice but to get the BB module working.
I now have the cable to connect to the versatility system with Ovida.
o0timbo0o thanks for the reply, i have enabled the module and it is detected within Ovida.
Basically the problem is that the broadband module (im assuming the DHCP in specific) is not assigning the computers that i connect IP address information, hence the limited or no connectivity and why they are being assigned 169.254 local system ip addresses.
My problem is i can't figure out why the broadband module is not allowing computers to connect to it and assiging them the details they need to communicate properly.. or at all...
Any ideas?
also FYI the bb module is installed with firmware version v189.
Thanks, Steve
