Re: BT Versatility - avoiding using '9' for external lines
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
This wouldn’t really be possible.
You could ‘hotline’ an extension to always dial a 9 when it is picked up but this would mean it could not make an internal call. This can also not be done on extension 20.
The Versatility Featurephones have line keys along the bottom that can be used instead of a ‘9’.
If the phones you are using have memory keys where a number is stored you could store a 9 under one of these and use that key to emulate the line keys on the featurephones.
Unfortunately the Versatility does not do the same as the Lucent system, as soon as you dial a valid number it rings what you have dialled. I.e if you pick up the phone and dial 0 it will ring group 11, if you dial 21 it will ring extension 21 immediately, if you dial 180 it will ring group 01 immediately.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
