Re: BT Versatility with fax machine.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi JavaBean
On the BT Versatility it is correct that you would require RJ-45 telephone adaptors (sometimes referred to as OSCA ADAPTOR) to be able to plug telephones into a structured cabling outlet.
The part about digital and analogue adaptors is incorrect, the extensions on a BT Versatility are analogue (regardless of whether the system has digital or analogue lines). In order to connect any of the devices mentioned you would need a PABX Mastered adaptor for each device (fax machine, PDQ or V Phone) as mentioned below.
You would not require an analogue card, the analogue card would only be required if you want to connect analogue (or PSTN) lines to the system.
In summary,
A) No you don’t.
B) PABX Mastered.
Hope this helps
Tracey
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
0
Kudos
0 REPLIES 0
