Re: BT Versatillity Is it our BOX or BT main lines into our BOX?
Fiona
Grand Guru
Hi
You would need to raise this as a fault to have the line and Box checked out, it is hard to determine just from the lights why a system may not be working.
Kind Regards
Fiona
BT Business Forum Moderator
Message Edited by Fiona on 22-06-2009 01:53 PM
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
0 REPLIES 0
