Re: LCR removal from phone system
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
I believe LCR is a table in the equipment which simply inserts the right digits to route your calls over Eurotel rather than BT. If this is not removed then the telephone calls will still be routed to Eurotel and charged by Eurotel (as the phone will still insert the routing code before a call is made).
You will need to have this removed to stop calls being routed to Eurotel, it is unlikely this would be done for free. You could contact BT Customer Services on 0800 800 152 to see if they could quote you a price, this may be different from Eurotel.
Kind Regards
Fiona
BT Business Forum Moderator
Message Edited by Fiona on 15-09-2009 09:28 AM
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
0
Kudos
0 REPLIES 0
