Re: acd
Fiona
Grand Guru
Hi
As far as we are aware, the dial IT software will sit on a PC, The Nortel Baystack product is a LAN switch, so there is no direct relationship between the two products. There is an indirect relationship in that the PC will likely connect to the LAN switch.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
0 REPLIES 0
