- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi, tried to set up my new email features with an HTC but I'm failing. Keeps coming up authentication failed. Please verify your username/password. Instructions for the ipad went great but struggling with this android HTC. Any help appreciated
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Cracked it.
On my galaxy S the solution was to copy in the details via the manual configuration route as per outlook settings apart from the username. Enter the username for each pop account as the full email address.
Pop server name: pop.outlook.com
Port 995
Encryption: SSL
Smtp server name: smtp.outlook.com
Port 587
Encryption TLS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am having the same problem, with my HTC Sensation running on Android. Any solutions?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
I've posted this before, but I'll do it again.
Check your email settings in something like Outlook Express (or Windows Mail if you're on Office 365). If they work perfectly then the problem is one of the following:
- Your settings in the phone are wrong.
- Your mobile provider has issues with BT email addresses.
If it doesn't work right then your email account might be broken.
That's pretty much it.
And I have a Sensation, just for reference.
Cheers.
Dave A
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same problem with my galaxy S. No problem until our recent switch to Office 365. I have changed over all the PCs (4) I use via the bt 'configuration utility tool' and these work fine with outlook and my POP3 emails (previously btconnect.com). The settings have been reconfigured to outlook.com for POP and STMP.
Should have been easy to just copy the settings into the phone hence I deleted the old accounts, not working after the switch anyway, and tried installing the new ones with the new settings. No joy via automatic detection or manual setup. The username and/or password are not recognised.
I have tried many many times over 2 days to get the phone to accept new settings and it will not. It is not due to mistakes entering the data - if only it was that wasy.
Help!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Cracked it.
Port 995
Encryption: SSL
Port 587
Encryption TLS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you so much for posting this. I've been trying, like yourself, for the last 2 days to get the email working on my Galaxy S2.
The important bit for me was
smtp server name: smtp.outlook.com
port: 587
Encryption: TLS
I'd been using SSL for smtp and it wouldn't work.
Thanks again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I too had the same kind of problem. This solution has helped me out too
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Cannot set my HTC to send and receive calls continues to say verify password/username
What can I do to resolve???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
i was having the same problem but i tried below steps and was able to install settings.
- open your web domain like (mail.xyz.com)
- click on forgot your password
- fill up your outlook email and the verification.
- you will receive a password on your outlook email.
- use that username and password in HTC and follow the instructions.
- i hope it works for you as well.
regards
Kashif
