Hi
I am trying to submit my website URL to the Bing search engine, I've submitted all of the pages, but I'm having trouble authenticating the site because I'm not sure how or where to put in the authorisation code. I'm getting the error message as follows:
We are unable to authenticate your permission to access this website. We tried both authentication methods and received the following errors with each:
XML File Authentication - We received a 404 file not found error when attempting to download the file.
HTML META Tag - We were not able to locate your authorization code.
Do I need to authenticate the site for Bing to crawl it, and if so does anyone know how to do it? I'm using Easysitewizard Pro?
Thank you.
Solved! Go to Solution.
Hi there,
Not sure how or where you are doing this but this site allows you to submit your site to bing and it's fairly simple and takes a couple of seconds.
Hi there,
