Replacement dongle
clearwater
Member
I've misplaced my BT dongle for use with my inclusive Mobile Broadband under Option 3 of the BT business broadband.  Can I get another one?! If so, how?
1 ACCEPTED SOLUTION
Accepted Solutions
Unobtanium
Member
Hi Clearwater
There's an FAQ with the contact details you need here:
Replacing your USB modem
Hope this helps
View solution in original post
2 REPLIES 2
JacobB
Power User
Give BT a ring, It may cost you a little bit. They would need to issue a new sim card. Otherwise the BT shop could be a Possibility.
Unobtanium
Member
Hi Clearwater
Hope this helps
