Router Security
couver
Member
I have had a 3rd party Netgear router for some time and recently noticed, when checking other routers in my area, that it is not protected as most others are. I am able to log into it for maintenance purposes. How do i apply security to prevent an unauthorised site using it and who supplies the service?
1 ACCEPTED SOLUTION
Accepted Solutions
OldWolf
Guru
Hi,
Found using 'netgear wireless security' in Google:
http://support.netgear.com/app/answers/detail/a_id/112/~/secure-your-wireless-network%3A-wpa%2Fwpa2-...)
(Just for reference BT don't support Netgears, only the routers they supply)
Hope that helps.
Cheers.
Dave A
View solution in original post
3 REPLIES 3
OldWolf
Guru
Hi,
Hope that helps.
Cheers.
Dave A
couver
Member
Thanks Old Wolf, problem sorted!
OldWolf
Guru
Hi,
No problem. Glad to help.  🙂
Cheers.
Dave A
