SMTP address for printer/photocopier
kmocho
Member
We have just had a BTNet leased line installed in our premises but our office printer/photocopier/scanner requires a  new SMTP address to enable it to send scanned documents to recipients. I have been calling and speaking to various technical support people but no one seems to be able to give me this (or know what I'm talking about, which is a bit worrying for a technical support department...). I've got as far as someone telling me I need to register (what exactly I do not know) at this email address: [email protected] but haven't had a response from them yet.
It should be as simple as 'smtp.btconnect.com' for example (but it isn't that coz I've tried). I am desperate to get our scanner function up and running again to send documents but can't until I have this address. Would be good to get instructions for the settings (i.e. does it need authentication, should SSL be 'on') etc, etc.
Any help greatly appreciated!
1 REPLY 1
Burkem5
Guru
Hi there @kmocho
What you need is the full email settings for whick ever email this is set up as.
So you you are using a BTconnect email in the printer/photocopier you will need to use
Server - smtp.office365.com
port – 587
connection type – tls
make sure the outgoing server requires authentication and authenticate with the same details as the incoming server
If you are using a BT hosted domain its the same details.
If you are sing a NON-BT domain and have mail relay enabled for that domain then it is the smtp.btconnect.com
Can you tell me whether the domain is BT hosted or non BT hosted?
Burkem5
