Another question, I was led to believe the SSL certificate came free with my eshop package. But when to go to the link you are charged for it. Is this right or do you fill in bank details but you don't get charged.
Which is better SSL or Trusted shops. Or can you have both.
Thanks again for your help.
Horse & Pony Tack Shop
You can't use your own SSL certificate on the eShop so don't bother buying one.
There is free SSL on the eShop, it just doesn't use your domain that is all. It uses the btowstore.com domain as you have found out on the other thread.
No Alistair, you are thinking of the normal web hosting package which allows you to use your own SSL certificate.
The eShop does not allow this and you have no choice but to use https://www.btowstore.com for all SSL stuff.
