Samaung Galaxy S3 WiFi Connection Problems
111Robin
Member
I've just purchased the Galaxy S3 but cannot achieve a WiFi connection with my BT Business Hub (BT2700HGV). After entering the WEP code it trys to connect (stating excellent signal strength) but eventually stops, stating connection disabled. All other WiFi devices connect without any issues. Do I need to change some router settings to enable a connection or is it the phone settings that are incorrect ?
2 REPLIES 2
alendam1
Member
Last week I purchased a Samsung Galaxy s3 GT 19305T. At home I have a Billion 7404VNPX Router. but not able to coonet with this..........
Online business listing
JonesyBrown
Member
The way i used to connect galaxy S3 to wireless internet is here: Tap the 'Apps' icon in the bottom right. In the list locate the 'Settings' Icon (if you can’t see it try scrolling left/right) Tap on 'Wi-Fi' to see the local wireless networks. You should make sure Wi-Fi is turned on, by sliding the switch at the top on the screen. Tap the network you want to connect to and enter the wireless key. It is works well
