Hi.
I've created a holding page for a website I'm designing on the secondary domain dm-joinery.co.uk. I followed the instructions to Frame forward it to the main domain completepropertymaintenance.co.uk using /public/newfolder. You are told that it would be 24 hours before it would be active. I clicked on the preview button and nothing happens.
It has now been over 36 hours and nothing has happened.
What am I doing wrong?.
Thanks.
Solved! Go to Solution.
Hi, you will need to remove public from the frame forward address completepropertymaintenance.co.uk/public/newfolder so the correct index page for your secondary domain can be referenced. Also, ensure that you only have one public folder on the server as more than one will cause conflicts.
Thanks Lancelot worked a treat.
