I am having a new business line installed tomorrow AM which will be the support line that connects to the lift control room should someone be stuck in the lift.
I have had a contractor pre run a CAT 6 cable that goes from the location of the master socket to the control room. Just to double check, will a MK BS6312 be ok to use for a secondary socket? Just looking for some confirmation otherwise I will order a secondary socket ready.
Thank you
***Mistake (MK BS6312) - MK Master Socket*
@bhartleyy wrote:I am having a new business line installed tomorrow AM which will be the support line that connects to the lift control room should someone be stuck in the lift.
Thank you
All MK telephone Master and Secondary outlets are either independently.
I have had a contractor pre run a CAT 6 cable that goes from the location of the master socket to the control room. Just to double check, will a MK BS6312 be ok to use for a secondary socket? Just looking for some confirmation otherwise I will order a secondary socket ready. ifacetimeapp
Thank you
