Hi
Having looked at most of the other posts about setting up static IPs on non-BT hardware (specifically DrayTek Vigor) I still have some questions.
I have been provided with the following by BT:
You’ve ordered a range of Static IP addresses, which contains 8 addresses from 217.xxx.xxx.129 to 217.xxx.xxx.133. Three of these are reserved:
My questions are:
1. Do I set the WAN IP or do I let that assign dynamically?
2. If I do set it, is that the network address above?
3. Can I set the static IPs (217.xxx.xxx.129 to 217.xxx.xxx.133) as WAN IP aliases?
4. If not, must I create an IP routed sub-net using the router/Hub address and sub-net mask above?
5. Is there anything I've missed?
Robin
Solved! Go to Solution.
Hi, this is just my opnion but would be best to get a confirmation from them.
1. You need to assign them statically.
2. Yes
3. With the Subnet that you gave, you can assign .129 to .134
4.
5. That's it. You can just assign a private IP in your LAN side of the router
2. Yes
4.
Thanks for the help - that's working fine now.
Robin
