Hi
We are having problems with our broadband speed, which used to be 10Mbps + and is now down to around 1Mbps.
We have tried all the suggested troubleshooting on the site, tried the online chat and was on for nearly an hour while they ran line tests from their end and said we should be getting 14 - 15 Mbps, then took over a PC here and did the wholesale test which said 1 Mbps was all we able to get, and then went on a sales pitch for infinity, but as we are a charity we're not willing to fork out more money unless there is nothing that can be done with our existing broadband.
Anyone have any ideas as to what we could do to get the broadband back to a reasonable speed?
The wholesale test results were:
Download speed
achieved during the test was - 1.01 Mbps
For your connection, the acceptable range of speeds
is 0.4 Mbps-1 Mbps.
IP Profile for your line is - 1.01 Mbps
We are using a Linksys WAG350N router and we have a separate line for the broadband which is not used for anything else. We have tried a different router (BT hub) but still have the same problem.
Router settings:
Encapsulation:PPPoA
Multiplexing: VC
QoS Type: UBR
Autodetect: Enabled
Virtual Circuit 0/38
Modulation: MultiMode
Any help anyone can give would be appreciated.
Your modem stats such as Sync Speeds, Attenuation, SNR or Margin is a starting point.
I'll also send you a Private Message.
Hi
Thanks for your reply and message. The router stats are:
DSL Upstream Rate: 632 Kbps
DSL Downstream Rate: 1152 Kbps
Down up
DSL Noise Margin: 23.6 dB 7.3 dB
DSL Attenuation: 24.5 dB 22.9 dB
DSL Transmit Power: 19.1 dBm 12.3 dBm
It looks as though you have been capped or banded - 1152 tells me that. Based on your Downstream margin you should definitely be seeing in the order of 15Mbps.
I see from tee message that you have also posted as suggested and that will be a better source for assistance - so, if necessary I will contribute there along with others.
