Description:
An issue has been identified when using BT Access Manager and the latest Intel® PRO/Wireless and WiFi Link Drivers (version 12.4.4.5). When BT Access Manager is started with the Wi-Fi device enabled, a BT Access Manager component causes a Stop Error (AKA Blue Screen of Death) with a IRQL_NOT_LESS_OR_EQUAL message,
Fix:
A patch is available from here to work around the issue. You should only install the patch if you are experiencing the issue described above.
Alternatively you could install an earlier version of the Intel drivers.
Tim
BT Access Manager Development Team
I'm using WiFi Link Driver (Version 13.0.0.107) and getting the BSOD. When I try and run the patch is says "A compatible client is not installed".
Is this patch specficially for version 12.4.4.5?
I get this issue on a Lenovo W500 running Windows XP SP3 with BT Connection Manager v1.98.0.0
The network drivers are all the latest versions for a type 4063 laptop as published at the Lenovo website, and the same dongle works on a T41 running at the same software level.
Unfortunately, the BT support I received claimed that no similar issues had been reported and that they couldn't do anything about it...
Is there a patched btomonwi.dll available for the connection manager version mentioned above?
There's a new version of the patch that works with the latest BT Access Manager (1.9.91.0) at:
http://accessmanager.btcm.info/client/patch/am_intel_wifi_12_4_4_5_patch.exe
The patch for the latest version of BT Connection Manager (1.4.98.0) is at:
http://connectionmanager.btcm.info/client/patch/cm_intel_wifi_12_4_4_5_patch.exe
Is there any way to silently install the am_intel_wifi_12_4_4_5_patch.exe patch.
