Hi, Im using easy site wizard pro and i have a website up and running. What i would like to do is create sub-menu's to the main menu buttons. i have tried to find in the help files but i have failed.
I'm not really sure. I checked their help page and I'm getting the same thing. I'm thinking that this is not a feature of the script "yet".
Would be nice if an employee can confirm this. ![]()
If you click on the menu editor and click "add button" underneath the main button that you want to add the button under, it should add a sub menu button
Hi, thanks for the reply. I have done that but they all appear on the web page. what I would like to do is to create a button that I click and the sub-menus drop down from .
Anthony
Did you ever get a reply to your problem?
I too would like to create a submenu using the existing Wizard functionality but I'm getting nowhere.
How did you resolve your problem?
John
