This is a suggestion for BT eShop development team......
I feel that the "Add to shopping basket" link on a product page is difficult for some customers to find. This link must be 100% clear. Our sales rely upon it.
Any chance it could be made to look like a button with user-configurable colour options?
Solved! Go to Solution.
Hey man!
You forgot the "()"
<style>
.LinkBasket {
background:url("http://www.rikkismusic.com/WebRoot/BT/Shops/BT3146/MediaGallery/Add_to_Basket.gif") no-repeat scroll 0 0 transparent !important;
</style>
Hello,
thank you for your suggestion. We will foward this to the development team to analyze how to improve this.
Best Regards
Hi,
perhaps this is helpful:
Go to Settings -> General Settings -> Advanced Settings
...and enter the following code in the text area:
<style>
.LinkBasket {
background: url("ADRESS OF THE IMAGE YOU WANT TO USE") !important; /* You can use the file manager (content menu) of your shop to upload one you like, the adress to enter in that case for your shop is "/WebRoot/BT/Shops/BT3146/49A4/9A96/C951/EB95/B5F7/0A0A/33D4/C307/FILENAME" */
padding: 1px 0 3px 20px; /* These are the default values, edit them if you like to fit your new bg image */
</style>
Cheers!
EDIT: forgot adding the <style> tag... Now it should work properly
thanks for the tip, moellthemaggot
I just got round to trying your idea but unfortunately I couldn't get it to work. I uploaded an image using File Manager. Then inserted the following code:
<style>
.LinkBasket {
background: "http://www.rikkismusic.com/WebRoot/BT/Shops/BT3146/MediaGallery/Add_to_Basket.gif" !important;
</style>
I'm not an HTML expert. Do you notice anything wrong?
Cheers for any help
Hey man!
You forgot the "()"
<style>
.LinkBasket {
</style>
hi moellthemaggot
It worked an absolute treat. I knocked up a button in photoshop and added as per your advice.
Here is button on product page (very happy):
Here is button on category page (not so happy but prepared to live with it):
Thanks a lot for the tip. I really appreciate it.
