Turning off Static IPs ?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Having activated the static ips and not had any luck getting them to work for my IP cameras ( which is working fine on the dynamic link). ...I then turned to DDNS. Recently found out that the Hub can be set up with DDNS (No-ip), so I set up my free account and the system works well up to a point. The Domane address is updated (good) but when I use the domane name xxxx.no-ip.org the address is redirected (at BT?) to one of my static address. !!!! There is nothing on the end of the static address- it does not ping. I had thought this was turned off at the Hub
Q How do I remove the static IPcompletely and the apparent redirection from no-ip ? Still learning....
0
Kudos
0 REPLIES 0
