Hello all.
Is it possible to remove a published site from the internet without deleting it. I might need to do some editing spread over several days and don't want the site accessible while it is a work in progress. I would then want to publish it again.
Thanks in advance for any help.
Mike
Solved! Go to Solution.
i dont know specifically.
but i'll tell you what i did.
i build another site with one page as a holding page and published it.
then once my site was ready i published that.
worked for me
worked for me
You could simply rename the home page.
I did the same as Alastair and put on the new one page site that the site was under construction and would be available soon. I also put my contact details on it so that I would not lose business.
