Unable to access my website www.marans-bantams.co.uk
Marans-Bantams
Member
Hi,
Help please I set this web site up  using Easy Site wizard it is the only web site I have.  At first it worked when myself or friends put www. marans-bantams.co.uk into their search bar but now when you put the web address in it goes to a page Helm webhosting control system???
Why is it doing this and how can I get my address to work.  I chose the Easy Site wizard because it was easy to use.
Thanks to anyone who can help
Gina
1 ACCEPTED SOLUTION
Accepted Solutions
WizApprentice
Power User
Hello.
At 23:32 (11:32pm) the web address www.marans.bantams.co.uk   displays English Cuckoo Marans and French Marans with photographs of three Cockerals and Fowl. If this is your webpage then the web address is connecting ok from a UK based computer.
If you found this reply helpful, please add a Kudos by clicking on the star sign. Thank you.
View solution in original post
3 REPLIES 3
WizApprentice
Power User
Hello.
JohnE
Guru
I concur with WizApprentice, your site seems to be working fine as at 10:46 20/04/2011: http://www.marans-bantams.co.uk/
Marans-Bantams
Member
Hi
Thanks for that!  Just not getting it on mine....  will try clearing all history and try again.
Thanks again
Gina
