Unable to access public folder
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
I'm using FileZilla and Dreamweaver and neither is able to access the public folder of my website. In FileZilla it times out after the message Response: 150 Opening ASCII mode data connection for file list.
I guess something similar is happening in Dreamweaver as it won't connect either.
The permissions on the Public Folder are diffrerent from the others i.e. drwx--S---. The others don't have the 'S'.
Not had any problems in the past. I can access the folder through the File Manager on the BT website.
Anyone got any ideas of what the problem is? I'm running Vista in a 64bit Computer although FileZilla has the same problem on my XP laptop.
Tate
0
Kudos
2 REPLIES 2
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
In FileZilla, can you confirm, what settings you have for me please?
0
Kudos
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Might be worth reporting to support, see if they can replicate it. Occassionally permissions issues do occur and things need reset or adjusted.
