- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello all,
We have the bt business hub in our workplace and for the last two weeks I have seen this
Uncanceled Echo: 15.3 dB Suspicious - check phone filters and alarm
So I have changed the filter 4 times and still have the same problem.
We only have the ADSL on this line and the main phone.
I have tried the test socket and it's still the same, also when doing a line test it comes back clear.
Any ideas? as I'm pretty stumped.
Edit: Just noticed every time a call is made I can hear a noise on the line and the hub resets itself, also the max rate on the line is now at 3500k which I'm assuming is so the line can stabilize.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Not as yet, i did call them although had to go away on an emergency. Just got back.
The internet does seem alot more stable however and i am no longer getting noise on the line.
General Information
DSL Line (Wire Pair): | Line 1 (inner pair) | |
Downstream Rate Cap: | 8128 kbps | |
Downstream Atten. at 300kHz: | 27.7 dB | |
Uncancelled Echo: | 15.4 dB | Suspicious - check phone filters and alarm |
VCXO Frequency Offset: | 13.5 ppm | Ok |
Final Rx Gain: | 16.8 dB | Ok |
Impulse Noise Comp. Tones: | 0 | Ok |
Excessive Impulse Noise: | 0 | Ok |
Impulse noise protection: | 1.05 | |
Delay of latency path: | 8.00 ms |
Still shows a problem but for now i am happy, i think they must have done something to correct it while i was gone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It is almost certainly a physical line fault ... (and I can guess which). Nothing you can do, it will require a technician to sort it out.
Call technical support and explain all of your findings to them ... If possible call from another landline if you can as they may ask you to try recreating the problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the info, will call them tomorrow and post the findings.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Any update ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
General Information
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Today, bt sent a new hub, newer than the one i had and it shows no problems.
So i'm assuming whatever the problem was, it has been fixed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
i have called twice today as i was told engineer was to fix my line. im really unhappy that no one has got back too me. im an ex bt engineer and buissness customer and i expected better service. i still have fault on line and have wasted day waiting and making phone calls too bt. this is poor service. can someone take responsibilty for this repair and call me with a resolution.
<Edited>
Extremly disappointed and expect an explanation.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Remove your mobile number!
