When I was with TalkTalk my upload speed was in the regeon of 0.75Mbs, now with BT just 0.37Mbs, is there anyway of adjusting my profile to increase the speed to 0.75 again?
Solved! Go to Solution.
Hi Tarren,
Depending on what package you have with BT, will determine your upload speed, if you contact the helpdesk they can look at this for you. Here are the helpdesks contact options
Regards
markp
Hi Tarren,
Regards
markp
