- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have been trying to upload hyperlink files. Basically I have an image on the normal screen, but I wanted to open a new window with a larger image and more detail etc.
I put the text block in, highlight it, hit the hyperlink tab, then file etc, browse, select the file I want. But when I come to apply, it just goes back to the browse for the file bit.
I have shrunk the size of the image, modified it but no good! Any ideas :)?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I think this thing that you are referring to has a bug at the moment which makes the choose file box appear every time you try to click apply.
Until BT fix it, you should use FTP or the File Manager to upload your file to the public folder, and then create a hyperlink to the file.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
