Versatiltity Broadband Module setup for new Router
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Our Versatitlity system has had a working BBM for 3 years, which was set up for VOIP phones in remote areas in UK, our previous Belkin Router blew up and we have just installed a new Netgear Router, we have internat on PC's OK but the VOIP phones cannot connect anymore.
I note the IP addres of new router is 192.168.0.1 and the old one was 192.168.2.1.
Ip addess in DMZ of router is set to 101 outside of the DCHP which is 2 - 100 and TCP port 5566 if forwarded to IP 101 and UDP port 5567 is also.
What settings do I need to change in the BBM to allow the new router to work.
Previously the BBM was getting its internet connection from the router so this should also be the case with new router, but I obviously need to change some settings in the BBM to be matched with the new router.
Any advce appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I can't give specific advice as I don't have a versatility system, but it would make more sense to me to change the settings on the router to work with your network than the other way around.
It is usually very easy to change the DHCP range of the router - check under "LAN Settings" or similar.
Adrian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I agree with the above ^
change the new router to the same as the old one.
you can change the LAN address and DHCP etc range on netgears quite easily using the built in admin interface.
