Web Service Problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
I've recently implemented an ASP.NET Web Service and installed it, however, when I try and use it, it fails.
The Web Service is working perfectly on my test system, and also at a domain with a different provider.
The error message I get would seem to point to a problem with the BT servers not being configured correctly:
Unable to generate a temporary class (result=1).
error CS2001: Source file 'C:\WINDOWS\TEMP\teewv2fz.0.cs' could not be found
After searching for a solution, it would seem that this is a documented problem that Microsoft know about. The solution is to give the NETWORK SERVICE user system write access to the C:\WINDOWS\TEMP directory on the server. Obviiously I don't have access to this, so I'm unable to proceed!
Can anyone at BT help - or anyone else for that matter? I can't be the only one having this problem!
Thanks in advance.
Ian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi bigemrg,
I would contact the helpdesk to get a ticket raised to our hosting platform to get it tested to see if there is an issue.
markp
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
I contacted the helpdesk on several occasions, and eventually managed to get hold of someone who understood the problem.
The hosting company, Hostopia, eventually implemented a fix and I was able to proceed.
However, this took several weeks and many phone calls, and wasted lots of my time - considering I'd provided the solution on my initial contact with the helpdesk!
For future reference, here is a link to the bug report in the Microsoft knowledge base:
https://support.microsoft.com/en-us/kb/322886
Regards,
Ian
