Web pages won't load on IPAD and Mac Book Pro
Lucianus666
Member
Hi
I have checked my connection via Speedtest - 27 ping 38mb DL and 8.5 UL.
My problem is web pages.
I click on the BBC bookmark it just hangs
If I click back and then on my BBC bookmark - it loads
Webpages just seem to hang and never open
This occurs on my Mac book Pro and Ipad - sometimes they work OK.
I have even connected the Mac using ethernet.
My PC seems OK!
Any help would appreciated.
2 REPLIES 2
kuerten
Super User
95%, I think that this is a browser issue. Since your using a MAC, try to update both flash and Java.
If it's still the same, try to update your Safari. How about other websites with not much pics and videos on it? Do they load fine?
Jessica
Member
Hi,
Is it the issue with some particular websites and others work fine?
If yes, then the websites are heavy.
OR
You are getting the same issue with random sites then it is the issue with the browser. You have to un-install the older and install the new version.
