I followed the instructions to redirect my web address to an external hosted site.
attempt 1: BT Domains Centre>manage organicarchitects.co.uk> forward to organic.barireid.com
I waited the 24 hours and the service seemed to work, another 24 and the service is not working again.
attempt 2: exactly the same as above with exactly the same result.
attempt 3: exactly the same as above with exactly the same result.
now i am stuck, it's extremely frustrating trying to show someone the page after i have tested it, only for them to see the original holding page!
at the moment the domain centre advanced domain manager is telling me the redirect is in place, but i can see it clearly is not...
any suggestions as to the strange result i am getting with this service?
Solved! Go to Solution.
Hi there,
Please retest your site as I have corrected the issue for you.
The problem was that the forward had created a duplicate record rather than overwriting the original one, as it should.
This meant the site would resolve 50% of the time and not show anything the other 50%.
The records for the domain have now been corrected so that:
www.organicarchitects.co.uk and organicarchitects.co.uk both now point to: organic.barireid.com
Your issue should now be resolved.
Apologies for the inconvenience caused.
Regards,
Colin
Update: Currently working properly again! hope it lasts this time...
guess not then! back to wrong page!
(testing on three browsers)
Hi there,
Regards,
Colin
thanks colin
