What do you think of my website?
ayegardening
Member
I have just redesigned my website using the easy site wizard, it was not easy though! I use a different program before but thought i'd give this one ago. Any comments would be appreciated, many thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Noahs_Ark_Gifts
Power User
http://www.ayegardening.co.uk/
Just thought it might help you to get more replies to your post.
I would try to keep all your typefaces the same or at least use either serif or sans serif and not mix the two.  Also I would take the visitor counter off.
Why not try adding a gardening tip to the front page which you can update and also help your keyword count eg Why is it important to clear your lawn of leaves?
View solution in original post
4 REPLIES 4
Cantoris
Power User
I like it. It's neat, delivers its message and is free from gimmicks. There is good use of keywords.
Some minor comments:
The home page repeats some of its text quite quickly and sometimes has inconsistent capital letters. Not a big problem by any means.
For your customer feedback, do you want to check with people that they are happy for their names and comments to appear on the site?
Overall, well desgned and executed.
 Nigel.
Noahs_Ark_Gifts
Power User
ayegardening
Member
Thank you for the reply, that is really helpful and I will check those things. My husband has permission from everyone to use their feedback. He has just changed the site again! lol because there was so many things that can't be done on the BT easysitewizard thing.
Thanks again for your help.
ayegardening
Member
Really good idea about adding tips! Thank you Smiley Happy
