I have uploaded my website files to the ftp directory mydomain.co.uk/public/newfolder as the help page said I had to set up a new folder in which to place the files for the website I am hosting through my primary domain. All the files appear to be present, and I have checked the index file within the newfolder is all in lower case and no spaces. I have tried pointing my second domain name to the primary domain through the domains centre but the instructions are vague. Do I point to just the primary domian or do I point to the primary domain with /newfolder extension included. I have tried both but it seems to make no difference. When I clicked on the test button to test the link to my primary domain address nothing happened. So I pressed save and received an auto reply to my email within a few seconds setting out the changes to the zone settings.
Would appreciate some clarification on this process.
cheers, Al
Solved! Go to Solution.
Fill in the form below and ask them to remove all A records to allow your domain forwarding to work.
You will need to point the second domain to the www.yourdomain.com/newfolder
Make sure going directly to this displays a site before trying to set up forwarding to it.
You may also see that in the advanced domain settings there is a greyed out A record pointing to 209.235.144.9. If this is there then this will prevent the domain forwarding from working and you will need to submit a request to BT to have it removed.
Hi Dave - you got it first time, the address is showing as grey under the advanced tab in the zone configuration.
When you say contact BT, any suggestion on who/how?
cheers
Al
