Which SMTP?
Lectrician
Member
Hi.
I have a BT infinity service, migrated from standard ADSL set up years ago. I have no idea if we have a BT email, I've never opted to use one.
I want to setup my Exchange email server to send emails via the BT SMTP server, but not sure on the SMTP server to use for a business account? Not sure if it needs authentication either. I know you didn't used to need to authenticate if sending email on your own connection, only when roaming, but not sure these days.
On a different note, can BT setup a reverse DNS PTR record on my static IP?
Any info would be great.
1 ACCEPTED SOLUTION
Accepted Solutions
Plumly
Grand Master
Hi Lectrician
you won't be able to send out using BT SMTP Server as a SMTP Smarthost any longer as they go through office365,
In regards of setting up Reverse DNS
https://btbusiness.custhelp.com/app/contact_email/cj_cat/3789,3775,3964
thats the link to the correct form
View solution in original post
2 REPLIES 2
Plumly
Grand Master
Hi Lectrician
Lectrician
Member
Thanks for the link, rDNS all setup without problems or lengthy phone calls, which is great.
While with the rDNS setup, I should be able to send email directly from my exchange server via DNS without too much junking, I have opted not to, as sending via an SMTP relay generally results in less emails being junk-foldered by customers.  I have ended up paying to use the authsmtp service as my ISP do not provide a reliable SMTP service, and the domain hosts SMTP server seems to end up with all the emails in the junk folders 😕
authsmtp.com's SMTP server seems reliable, as does 1and1's SMTP server (I can't use 1and1's on this occasion as the domain is not with them, but I do use theirs on other sites).
