Wireless Bridging 2 x Hub 3 and 1 x Hub 5
Timc1
Member
I have successfully added a spare BT Hub 3 as a wireless access point to a Business Hub 5 using Powerline ethernet adaptors.
To avoid drilling through a 3' thick loose stone wall I now want to add a second Hub 3 to connect wirelessly to the First Hub 3 ( Wireless access point ) and then on through the powerline adaptors to the Hub 5 and the internet.
just joined this forum so may have missed previous answer to this
Any pointers greatfully received.
Tim
1 REPLY 1
markp
Grand Guru
Hi Timc1,
It is not possible to use our hubs as a wireless bridge connecting each other via wireless the only way is can be done is if the are connected to the main router via ethernet.
Markp
