Hi can anyone help me......really frustrated.
i have picked an advance template and it gives me a list of options where to save.ie public.
Onced saved how do i find them in the site editor?
You would think the logical way would be to save them in the designs section of which there isn't a listing to save in.
any help would be appreciated before i hit the bottle........
thanks
chris
Solved! Go to Solution.
You will not be able to edit these templates using the online site editing tools.
The message at the top of the Advanced Template Manager that says:
"These templates are compatible with third-party website authoring software"
actually means:
"These templates are compatible with third-party website authoring software. You will not be able to edit them using EasySiteWizard 6 or Pro"
They are aimed at advanced users and are meant for downloading then editing using software like Dreamweaver, etc
actually means:
Hi
Dave is correct. The Advanced Template Manager is only for third party programs and not Easy Site Wizard.
