HI all,
Are there any better links than the ones provided in easy wizard - they're pretty lame and TINY if screen resolution is set to 75%
Cheers
gusm,an
Solved! Go to Solution.
Assuming you are referring to EasySiteWizard Pro then normally you can't edit the links.
However, a trick is to add a space after the link text then select the test including the space. You should now be able to do all the usual font functions including changing the size. You can then remove the space once you have it the way you want it 🙂
thanks dave ill give that a try !
