block websites
SykesIT
Member
Hi i am trying to get a definitive answer on if the BT business hub i think 3 can block websites. Some say no and others say yes.
1 ACCEPTED SOLUTION
Accepted Solutions
markp
Grand Guru
Hi SykesIT
The Business hub3 and 5 do not have a content filter for blocking accesses to certain websites.  If you are wanting to restrict access you would need to setup your own hardware firewall to block the sites.
Markp
View solution in original post
2 REPLIES 2
markp
Grand Guru
Hi SykesIT
Markp
SykesIT
Member
Thanks that is what I though but wanted a definitive yes or no.
