can anyone help when I send a email using my alias email address using Outlook Web Access
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi… can anyone help when I send a email using my alias email address using Outlook Web Access where you would have your name or company first I get xxxx@btconnect.com then mymail@mydomainname.co.uk how can I change the btconnect part and replace with my name….I have setup the personalise the default sent from email address....thanks ...Dave
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Dave,
Ok I just want to check if you've gone through the steps.
First off you need to create an alias, and then allocate the alias to your @btconnect.com email address. Finally you change the default 'From' address to the alias address.
All this is done through the website at http://myoffice.bt.com, and you're logged in as the primary @btconnect.com user.
So far so good?
Cheers.
Dave A
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi There,
This may help.
http://btb.lithium.com/btb/board/message?board.id=EmailBoard&thread.id=1259
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi ..I have done all that... using Outlook express it works all ok with the company name then the alias email address
but using Web Mail I get on headers my xxxx@btconnect then my alias email address I would like to change the btconnect to the company name as it is in outlook express....thanks Dave
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
any sort this out as i have the same problem.
Everything other than webmail is fine.
Webmail email appear to come from
<someone>@btconnect.com [<someone>@thealias.com]
We need to not show the btconnect.com part.
thanks
Simon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
Thats a backend issue on the mail server, call technical on 0845 600 70 20 to report it. That functionality should work across webmail.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks,
eventually got though to email support, who agreed there is a problem (checked the headers and all settings) they have forwarded the problem to back office. I hope thats not another word for bin
Cheers
Simon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Nope, back office is ideal 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks Guru Spank
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No problem...'member' doesn't sound so good does it, I think they should change that to 'Aspiring Yogi' to stay in context.
