Hi Paul,
Sorry to read about the problems you are having with your line.
There are several different reason as to why you could be having a slow speed issue.
What I would suggest is for you to contact the Technical Help team, they would be able to run diagnostics with you.
Hope this helps
Tracey
BT Business Forum Moderator
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
