combining dreamweaver with bt's easy blogg
reptilehunter
Member
Hi folks I have a bit of a strange question.
What I was wondering is can I incorporate my website I created using dreamweaver with the bt easy blogg and photo album because I think they could be a useful asset.
I don't really want to just give up with my dreamweaver site as it has took me ages but if have to then I have to.
Really hope some one can shed some light on the situation and hopefully its good news,LOL
anyway I look forward to your responses and can I just say I am so glad we have this forum other wise I would be totally lost,LOL
5 REPLIES 5
duskjome
BT Partner
BT Partner
This shouldn't be a problem, your blog builder publishes into a folder called something like yourdomain.co.uk/cgi-bin/ebb/blog2/index.php so as long as you leave that folder up when you upload your dreamweaver site you should be able to use both. The same is true for most site building tools as well.
Hope this helps.
reptilehunter
Member
thank you very much, i will go give it a go. thank you again
reptilehunter
Member
Sorted was alot easier than i thought. thank you
k11ngy
Member
I was going to ask same question but its answered and thanks for information.  One question I do have (I am newbie) If visitors are looking at my website home page, or any pages,  how do I direct them to the blog?
regards
Steve
Fiona
Grand Guru
Hi
You can create a hyperlink to your blog on the any part of any page using EasySiteWizard application.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
