Someone completely deleted my SQL Server 7 database. I retrieved the .LDF and .MDF files from a network backup. Now I am trying to attach the database. I have tried this without creating an instance of the database by using the attach stored procedure to attache the .LDF and .MDF files I retrieved from the network backup. Also, I have tried it by creating an instance of the database and doing a detach of the newly created db .LDF and .MDF files and an attach of the .LDF and .MDF files I retrieved from the network backup. Neither of these approaches have worked.
Here is what I have tried in the Query Analyzer, but to no avail:
For the following example, I created a database instance called 'qarun_diamond_48_brett' with brand new .ldf and .mdf files and then tried to detach and then attach the .ldf and .mdf files from the network backup:
use master
go
sp_detach_db
'qarun_diamond_48_brett', 'F:\APPS\SQL 7.0\Database\Data\qarun_diamond_48_brett_log.ldf'
Message: Usage: sp_detachdb <dbname>, [TRUE|FALSE]
use master
go
sp_detach_db
'qarun_diamond_48_brett', 'F:\APPS\SQL 7.0\Database\Data\qarun_diamond_48_brett.mdf'
I tried the following attaches of the retrieved/recoverd .ldf and .mdf from the network to the newly created db instance. That didn't work, so I tried attaching to a db that had not yet been created.
use master
go
sp_attach_db
'qarun_diamond_48_brett2', 'F:\APPS\SQL 7.0\Database\Data\qarun_diamond_48_brett2_log.ldf'
Message: Server: Msg 1801, Level 16, State 3, Line 1
Database 'qarun_diamond_48_brett' already exists.
If I use a different db name I get the following error:
Server: Msg 5105, Level 16, State 13, Line 1
Device activation error. The physical file name 'qarun_diamond_48_brett' may be incorrect.
use master
go
sp_attach_db
'qarun_diamond_48_brett2', 'F:\APPS\SQL 7.0\Database\Data\qarun_diamond_48_brett2.mdf'
I have also tried these statements wtih the EXEC sp_attach_db and EXEC sp_detach_db commands from within the Master db in Query Analyzer.
Any help would greatly be appreciated.
In any case, if these suggestions don't work, you can try to repair .mdf file. You can try MDF Repair Kit. It's not free, but reliable.
Thanks for the advice. Your link was very useful for me! Thank you!
