Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Does anyone know a way to delete gooles maps from a website. I added three by mistake to my site.
Hobgoblin
Solved! Go to Solution.
0
Kudos
1 ACCEPTED SOLUTION
Accepted Solutions
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi.
If you used the Easy Site Wizard Pro, you can double on it and you will see a red X appear on the bottom right hand corner. This will allow you to delete the google map.
2 REPLIES 2
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Was it ESW Pro that you used? If so you should be able to double click the title bar of it, and then the delete button should appear at the bottom of the map window.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi.
