I have Infinity 2 and my line speed is fine. If I connect using a windows PC directly to BT's VDSL modem (logging in with PPPoE directly) I get 77/19 compared to a theoretical 80/20. Tested both on BTspeedtester and speedtest.net. Have also treid direct "fetch" (All figures Mbps unless otherwise stated)
However if I connect via ANY router (with the router logging in via PPPoE) the speed drops to 28-33/15-17. For the upload this seems reasonable to drop a little for the extra overhead, but the download is losing more than half the speed.
I have tried various routers with similar results - including hardware based and Linux and BSD based. Have tried different NICS. All of these routers are capable of much higher speeds - subsituting internal server for fttc sees speeds in excess of 400.
I am beginning to suspect MTU - have been using normal 1492 on all routers, as per RFC1516. I gather that BT's implementation of fttc may be compatible with MTU up to 1500 as per RFC 4638 - so direct connection to PC may use this.Is this correct and could it be relevant?
For example - is it possible that upsteram from VDSL modem uses 1500 - which is passed through with direct PC connection, but via router (with MTU of 1492) fragmentation occurs - reducing the speed?
Frankly I am at a loss to know how to even determine the real cause - let alone fix it. It may well be nothing to do with MTU - but I have no other even vague ideas?
Any suggestions as to either how to fix the problem - or at least how to further troubleshoot?
Thanks to anyone in advance for suggestions
The BT FTTC Hub (2wire 2701) will default to an MTU of 1492 so any PC needs to be that or lower.
The only MTU setting I don't know for sure is direct PC PPPoE connection but I guess this defaults to 1492. In any case - as this is direct PC direct to VDSL modem using PPPoE (No HUB) this is the only one that gives maximum speed.
All the other settings are definitely 1492 - as per my message above.
ADDITIONAL
I suddenly thought - why not check mtu under PPPoE. So I connected direct from PC to VDSL modem using PPPoE. Checked speed - 76/18 - pretty good. Then checked mtu (netsh interface ipv4 show subinterfaces) - very surprised to see that PPPoE was 1480. Normally win7 would give 1500 for LAN interface. Not sure what this means - but I will try setting different routers to lower mtu to see if any effect.
