e shop
davesgirl
Member
Hi
Hope someone can help me I have most of my web site and whish to add pay pal buy now buttons to it
but try as I do I cannot do this I can copy from pay pal but it will not paste into east wizard pro
so what do I do I am pulling my hair out right now
I really need a step by step tut if anyone has the time I would be grateful
thanks M
1 REPLY 1
eShopTeam
Master User
Hello,
you can not "copy and paste" the images.
you can add images to your shop by uploading them to the media gallery and adding them into the text field.
Go to the category, where you want to add the logo. Go to text. Go to edit text and then to the insert document button. Here you upload the image and then insert.
If you would like to add a logo on the start page you need to insert a user defined site element. Go to design and click on the part of the page where the logo should go. Then click on insert page element and then a window opens and you click on the right buttom side insert text (html). then do the same as above, click on text and insert the document. If you do not have any user defined elements left, then it is not possible to insert the logo on the storefront.
The eShop Team
