eShop Direct Login Desktop Shortcut
arredare
Member
Is it possible to create a direct login desktop shortcut for the eShop? ie, a desktop shortcut that will open the ePages MBO (Merchant Back Office) without the need to re-enter login details each time.
I'm currently opening the MBO by going through BT.com - but it's very cumbersome (about 5 clicks/screens to get to the MBO)
www.arredare.co.uk
1 REPLY 1
pusaqall
Member
You might need a third-party software to program that you need to be done.
