hello
i have noticed that i have a very low snr (around 3db) and a 2270 kbps connection with a 57db attenuation.
others nearby (therr is only one green box where i am serving 300 premises), are getting a solid 3.8Mbps at 6db.
i only have the router connected directly to the test socket less than a meter away. there are no extensions connected too.
ive done a quiet line test and had no issue. the bt helpdesk ran a line test and found no problem.
ive tried the bt hub, draytek and now a billion 7800n router and not had much difference.
here are my line stats
> adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 8000
Max: Upstream rate = 736 Kbps, Downstream rate = 5496 Kbps
Path: 0, Upstream rate = 444 Kbps, Downstream rate = 2270 Kbps
Link Power State: L0
Mode: ADSL2
TPS-TC: ATM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 2.6 14.5
Attn(dB): 57.5 33.7
Pwr(dBm): 0.0 13.1
ADSL2 framing
MSGc: 89 10
B: 6 63
M: 1 1
T: 7 1
R: 6 0
S: 0.0966 4.5309
L: 1076 113
😧 320 1
Counters
SF: 1016558 901436
SFErr: 215 29
RS: 676011486 0
RSCorr: 1944195 0
RSUnCorr: 5038 0
HEC: 143 12
OCD: 4 0
LCD: 0 0
Total Cells: 87462431 17102659
Data Cells: 26410217 1910997
Drop Cells: 0
Bit Errors: 0 1287
ES: 89 15
SES: 1 0
UAS: 90 90
AS: 16335
INP: 7.13 0.00
PER: 16.06 18.12
delay: 7.73 1.13
OR: 47.29 7.06
Bitswap: 79 74
Total time = 4 hours 34 min 54 sec
FEC: 1944195 0
CRC: 215 29
ES: 89 15
SES: 1 0
UAS: 90 90
LOS: 0 0
LOF: 0 0
Latest 15 minutes time = 4 min 54 sec
FEC: 6296 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 19764 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Latest 1 day time = 4 hours 34 min 54 sec
FEC: 1944195 0
CRC: 215 29
ES: 89 15
SES: 1 0
UAS: 90 90
LOS: 0 0
LOF: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Since Link time = 4 hours 32 min 15 sec
FEC: 1944195 0
CRC: 215 29
ES: 89 15
SES: 1 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
i've check on the wholesale checker and see the following for my number, which makes me think i am basically locked at 2Mbps. the router stats show that i am on adsl 2.any suggestipns as to how i move the issue forward to get a bit more ?
thanks
Available ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Featured Products | ||||
| WBC ADSL 2+ | Up to 6 | -- | 4 to 8 | Available |
| ADSL Max | Up to 5 | -- | 3.5 to 7.5 | Available |
| WBC Fixed Rate | 2 | -- | -- | Available |
A couple of suggestions:
1. Double-check all your internal wiring, low SNR margin often points towards issues in the premises.
2. If the router allows it, change the mode from ADSL2+ to G.DMT. I have a long line issue (~4km) as well as aluminium cabling between here and the cabinet, so I was never going to see the benefits of ADSL2+. Changing to G.DMT has made increased the SNR from around 5db to 15db. It hasn't increased the sync speed by much (2072kbps to 3584kbps), but it is rock stable now as opposed to having lots of HEC/FEC errors.
HTH,
Adrian
Adrian
Well, number 2 definitely helped. I selected only G.DMT and my downstream SNR has risen to 13.6 from 3. I just need to get the BT business folks to look at why I can't synch at a lower SNR, so maybe I can climb up a couple of notches in terms of profile.
Great work and thanks.
Fingers crossed I can move forward now.
Jet
