Is mod_rewrite enabled on the BT servers by default ?
Or do I need to ask for it to be enabled?
I am using htaccess file to try to get a 301 redirect to work using the code below:
Options +FollowSymLinks
RewriteEngine on
RewriteCond %{HTTP_HOST} ^classroompixie\.com$ [NC]
RewriteRule ^(.*)$ http://www.classroompixie.com/$1 [R=301,L]
Trying to redirect http://classroompixie.com to http://www.classroompixie.com
Having no joy and am kinda puzzled.
I have the BT advanced web hosting & business essentials package.
Anyone able to offer any suggestions.
Solved! Go to Solution.
it should work by default. I used almost identical code in my .htaccess file and it worked fine. The file was in the public folder.
Mine is:
RewriteEngine on
RewriteCond %{HTTP_HOST} ^domain.com [NC]
RewriteRule ^(.*)$ http://www.domain.com/$1 [L,R=301]
The only real difference is I don't have the \ in the HTTP_HOST line.
Mine is:
RewriteEngine on
No idea why but it now works.
Both the syntax I was using and yours seem to work fine.
Can only conclude that I must of been doing something different before.
Thanks for the super quick response btw.
Just wondering how I get my .co.uk url to point at my .com url now , purely for SEO reasons.
As when I ftp to them they both point at the same server space?
